Green Picture
Discussion in 'General TV Discussions Forum' started by Bigtop, Jan 11, 2005.
  1. Bigtop
    Bigtop
    As an AV virgin can anyone help me?
    I have a Panasonic TX-28PL10 which is now a few years old.
    Occasionally the picture will just fade out to either a completely red screen or more recently a completely green screen. It is a gradual process but eventually leaves the screen as a negative type image in a predominantly green transparent colour.
    It normally occurs after the TV has been on sometime and is normally ok again when left turned off for some considerable time - overnight!
    :lease:
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Hello Bigtop and welcome to the Forum. :)
    You clearly have a poor connection/dry joint somewhere, possibly on the tube base.
    Any competent technician should be able to locate this fairly easily with a can of freezer.
    I wouldn't suggest you try this yourself, as I'd hate this to be your only post!
  3. Bigtop
    Bigtop
    Tight Git,
    Thanks for that :D
    I thought I may have been looking at a new telly so will be looking for a reputable 'man that can'. :beer:
    Bigtop
