Green Lines on TV
petrolhead
I have a 32" WS Phillips.
I have recently noticed that the picture is suffering slich haziness and vivid green lines every 1-2" down the screen.
Messed about with picture and it does get better when in Super Zoom mode. More noticable on darker scenes.
Any thoughts or do I bin it :(
atmoscinema
I had red lines on a rental Philips one once and the tech guy said the red guns were on the way out.
Ring a tech to confirm.
O
oorwillie
It could be similar to the problem I had.
It only happened when I had my dvd player set to RGB output, the tv displayed green patches. The picture was fine if I used the s-video output instead. There was a thread about it a while back, I have a panasonic tx36pl30 and a pioneer 444 dvd player.
If you are using RGB output, try changing it to something else to see if the problem goes away.
Willie
petrolhead
The lines are there all the time, DVD, Terestrial etc
atmoscinema
Mine were as well.
atmoscinema
Thanks Wayne.
Don't suppost you have a number?
Ring the shop where you bought it from,or if out of guarantee,ring your local friendly TV shop.
