Quantcast
Green Flickering On Panny Pwd8
trottersplc
when my freeview box is connected to scart it starts to flicker green it does this on every thing connected to scart input. is my plasma on its way out or is the scart board buggerd
UKseless1
Do you have any other boards....or do you use the VGA input? If you could test the picture via the VGA or if you have a component board that you could use then you could at least determine if it's simply the board or the screen.
Have you got a laptop that you can connect via a VGA Cable?
Similar threads
