Green colour
Discussion in 'Xbox Forums' started by AVF Jazzy Geoff, Dec 23, 2006.
  1. AVF Jazzy Geoff
    AVF Jazzy Geoff
    Dec 20, 2005
    982
    43
    Portsmouth
    +165
    Hi all, after a bit of advice if poss, when i start my 360 up, the logo appears to have agreen tingue to it, checked all the cables and all seems ok. Any one else experienced this or have any clues as to waht it could be...thats all i need, the 360 packing up just befrore xmas...especially with gears of war waiting under the tree!!
  2. BFassassin
    BFassassin
    Sep 27, 2006
    294
    +10
    Which logo are you talking about? is it the one on the controller. If it is then its supposed to be green when the console is on so it shows which controller is connected
  3. TEVEZ032
    TEVEZ032
    Jan 16, 2006
    2,037
    +95
    i guess he's referring to the 360 logo onscreen on bootup.
    if so; try setting your TV to its default colour/brightness/contrast and see if that makes a difference.
    g
  4. Soundwave
    Soundwave
    Mar 9, 2005
    7,426
    Basildon, Essex
    +2,451
    Are you using Component??
    Mine used to do this & it was becuase the Red cable wasnt plugged in properly, reconnected them all & it was fine.
    Could be the same although I know you said you tried all connections anyway but could be it's just coming loose again or a pinch in the cable?
    Neil
  5. AVF Jazzy Geoff
    AVF Jazzy Geoff
    Dec 20, 2005
    982
    43
    Portsmouth
    +165
    thanks guys, good advice as always. changed the scart connection on the back of the tv and this seemed to do the trick
  6. blicky_1
    blicky_1
    Jan 23, 2006
    2,979
    Hampshire
    +516
    SCART?? :suicide:
    Someone get that man a HDTV!! :rotfl:
