green and red edges on panasonic TX36PF10 in RGB
Discussion in 'Televisions' started by Dale, Apr 8, 2003.
  1. Dale
    Dale
    Apr 8, 2003
    7
    My TX36PF10 is two years old and is used with S-video from a Toshiba SD100. If I use RGB, there is a slight green tint to right hand edges between flesh tones and dark backgrounds (such as a face surrounded by black hair). There is a less noticeable red tint to the LH edge. The effect is not dramatic, but is enough to prefer S-video, accepting the noisier picture.
    The Tosh DVD appears to be innocent, as the effect is not seen on an ageing 50 Hz Sony with RGB.
    I now want to connect a digital satellite and very few have S-video. Does the much discussed "DVC 0 adjustment" effect this problem?
    Otherwise, accepting the "only" average EHT regulation, this is a good TV.
