Greedy Scart
Discussion in 'TVs' started by windsurf123, Dec 5, 2003.
  1. windsurf123
    windsurf123
    Nov 14, 2003
    123
    +5
    I have a 28" Sony wide screen TV (about 3-4 years old). Connected to one of the scarts is a Yamaha DVD-S80 (plus matching surround sound amp)
    Problem is: Whenever the TV is first switched on, it momentarily goes to the last station viewed before "always" picking-up the scart imput from the DVD.
    This happens with the DVD player in standby/or on.
    Evey time I have to manually select a normal station to get away from the scart imput.
    It's like the DVD is constantly broadcasting itself even when in standby.
    Is there a way to stop this happening?
    Any help much appreciated.
  2. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    This is a feature of Sony sets, and others possibly.
    There is no adjustment on the tv to stop this happening.
    You can stop it doing this very easily, though. Undo the plugs on either end of scart lead and cut pin 8. This is responsible for sending a signal to the tv to ask your set to select the AV input.
  3. windsurf123
    windsurf123
    Nov 14, 2003
    123
    +5
    "You can stop it doing this very easily, though. Undo the plugs on either end of scart lead and cut pin 8. This is responsible for sending a signal to the tv to ask your set to select the AV input."
    Many thanks, I'll try this.
    Tim:)
  4. bockster
    bockster
    Nov 26, 2003
    46
    staffs (gods country)
    i'm sure that works but shirly you only need to cut pin 8 at one end!
  5. windsurf123
    windsurf123
    Nov 14, 2003
    123
    +5
    Finally got around to doing the suggested "pin 8 cut".
    Works a treat, many thanks
    :p
  6. sjallen
    sjallen
    Doesn't leaving the player in standby/off mode work? It does on a PS2.
  7. windsurf123
    windsurf123
    Nov 14, 2003
    123
    +5
    You'd think so, wouldn't you! But alas no, the Sony TV always picked up the Yamaha AV amp, even in standby. Was really annoying.
