Great Price In-Car portable DVD
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by rasb0, Mar 19, 2005.
  1. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Well Great Price IMO! I bought one today for the kids instead of Easter eggs (not that I would have spent £199 on Easter eggs mind!!) :D
    Costco are doing the Centurion PROPP70DVD for a tad over £199 inc. VAT (RRP is around £250, although it appears to be available on the net for £225).
    Inc's, 2 X 7" LCD screens, 2 sets of headphones (link below states 1 set but Costco's does have 2) and you have the no quibble return policy. :thumbsup:
    Full spec here:
    http://www.centurionsystems.co.uk/plugandplayblue.html
    If you're in the market for one of these, this could be the one. I know there was a recent thread on the subject of price and which one to buy.
    Just had a look at Monsters Inc. and it's fantastic. Hope the Kids appreciate it now they are 19, 21 & 22. :rotfl:
    No multi-region hack yet. Anyone help with this? :confused:
  2. A289
    A289
    Out of interest, do you know how it copes with home burnt DVD-R disks ? I want to record a shed load of CBeebies and hope that keeps the kids quiet in the car !
  3. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    I'll give it a try and get back to you. :)
  4. Andy Clark
    Andy Clark
    Feb 24, 2005
    986
    46
    A Long Time Ago in A Galaxy Far Far Away
    +104
    Try these:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=-9626&TabID=1&source=1&doy=22m3
    Today only. 24 left. £99.00 each, with voucher if you register you should be able to get them for £94.00 each inc. delivery.
    Just had two delivered, good quality, plays everything, SCART socket (not seen on may of these things), NO rechargeable battery so not portable if that was important to you. 7" screen that is seperate from the DVD player so easy to install/move around.
  5. stormjai
    stormjai
    Nov 15, 2003
    329
    Bromley
    +3
    does Centurion model have rechargeable battery, or must be connected to car power/ mains only?
    Ta
  6. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    No battery!
    Car/12V or mains.
  7. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    I've just got one and it appears to be 12v car lighter powered only. How do you run it from the mains ???? :rolleyes:
  8. SillySausage
    SillySausage
    Jul 10, 2004
    578
    Leicester
    +14
    Hia Davee,
    Buy one of these http://***********/3ojbe (Or a larger one depending on the current draw of the player. It should say what that is on the label)
    And one of these http://***********/4e52e
    Then mount the socket into the case of the dvd player, connect the wires up to the power wires coming from the normal 12v supply inside the case and off you go.
    Quite easy and cheap really, but will bugger the warranty up.
    I've done similar things on loads of 12V bits and pieces.
    As long as you make sure you get the right current and voltage power supply, and a plug and socket combination that mate up it is easy.
    If you are unsure abou it, maybe take it back into maplins and ask them for some help choosing bits.
    Adam.
  9. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    Thanks SS :thumbsup:
  10. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    This may seem like an odd question, but does anyone know if the "side wings" of the 12 v connector carry current or are they just there to keep the connector in place. Just that i had to pull them out a bit as the connector wasnt secure and kept coming out. Part of the bare metal of the "wings" now stick out of the top when the connector is in place and i'm concerned they may be dangerous. :eek:
  11. SillySausage
    SillySausage
    Jul 10, 2004
    578
    Leicester
    +14
    Hia Davee,
    The side bits are the earth connection for the power.
    The positive is the little nipple thing on the front.
    As long as the exposed bits do not come into contact with anything that has 12v going through it then it should be ok.
    Although check that the feed to the cigarette lighter socket has the correct fuse in it, just in case.
    Adam.
  12. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    Many thanks for the quick reply Adam :)
  13. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    Sorry to labour this point, but do the two external wings need to make contact with the internal metal strip to work correctly. The way i have modified the connection, when the connector is inserted the external metal strips make contact with the plastic body instead. :confused:
  14. SillySausage
    SillySausage
    Jul 10, 2004
    578
    Leicester
    +14
    yes they do.
    I'm in the middle of an on line game atm.
    will respond shortly ;)
    Adam.
  15. SillySausage
    SillySausage
    Jul 10, 2004
    578
    Leicester
    +14
    Back again ;)
    I think you may have a problem if you have bent the plug arms to the degree that they won't now touch the sides of the cigarette lighter socket.
    If you look into the socket, it should have a metal housing and the side prongs have to touch this in order to make the circuit.
    If you modify it at all, be carefull not to let any part of the side touch the bottom of the socket, as this is where the positive makes the connection.
    If it was me, I'd leave the cigarette lighter alone and buy a seperate socket (And possibly new plug as it sounds a wee bit fooked.. lol ).
    Then I'd wire the socket into the car at a convieniant place. As long as the feed is fused at the correct rating then all will be well.
    Or you could just buy a new plug from Maplins and cut off the damaged one.
    IIRC, you should be able to put a small flat headed screwdriver inside the side prongs and lever them out slightly to make the plug grip a little tighter if needed.
    Let me know how you go on.
    Adam.
  16. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    You're a star Adam....i'll head to maplins and get an extension, then hopefully connect to this more securely. Many thanks for all your help. :thumbsup:
  17. whatdoiknow
    whatdoiknow
    With the Centurion model, does it have separate AV in to each screen, so one could be used to watch a DVD whilst the other could be used for gaming.
    I believe a Venturer with 7" screens can do that, I think it is being sold by Argos for £199
  18. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    No. The AV-in is on the DVD player and not seperate to each screen.
  19. garyc
    garyc
    Dec 21, 2002
    866
    Jersey, Channel Islands
    +13
    Are any of these multi region?
    cheers
    Gary
  20. whatdoiknow
    whatdoiknow
    Thanks Rasb0 at least it has AV in so I could attach a portavle VHS VCR.
    Martin
  21. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    I'll give it a go tomorrow and report back soon after.
    I'm not hopeful and I haven't found any hacks for this model.
  22. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Tried a region 1 disc and the bad news is, region 2 only. :thumbsdow
  23. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    The venturer twin 6.2" screen one is great. Can have DVD on one screen, AV in (game etc) on other. Can be made multiregion via remote hack. Only problem is no resume on power off/on, so need a permanent live ciggy socket.
    Available from Argos on sale I think at 199.99 at the moment.
    HTH
    Dave
  24. PVR
    PVR
    Oct 23, 2002
    178
    16
    Nr Gatwick
  25. whatdoiknow
    whatdoiknow
  26. fjle
    fjle
    Aug 25, 2003
    3
    East Yorkshire
  27. PVR
    PVR
    Oct 23, 2002
    178
    16
    Nr Gatwick
    Excellent deal indeed, just ordered it as well, thanks !
  28. PVR
    PVR
    Oct 23, 2002
    178
    16
    Nr Gatwick
    How did you get yours so quick then? Do they have a physical shop somewhere or so ... it says 10 days for delivery
  29. fjle
    fjle
    Aug 25, 2003
    3
    East Yorkshire
    Yes they have a few shops all up here in Gods country.
  30. PVR
    PVR
    Oct 23, 2002
    178
    16
    Nr Gatwick
    Thanks for the tip, I was waiting for the summer hols, but for that price ...
