Great looks, great performance ?
Discussion in 'Subwoofers' started by smallangryboy, Dec 1, 2004.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    I'm thinking of chucking in my REL Q50 for something, well a little less square or just not black ! Budget runs to about £450 and it will partner satellites, possibly AG Nucleus or similar. I'm looking at :
    Anthony Gallo M150 [active]
    Kef PSW 2500
    Monitor Audio R360
    It has to work well with 2 channel music as well as big soundtrack film, trouser flapping bass would be great though I doubt I would be able to really crank up the system, so good bass at reasonable or low volumes is a must. Your opinions are greatfully received.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Have a read of all the info on the BK XLS200 on this site, it might well be up your street.
  3. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    Also at the same site as above the Ruark vita 100 and there is always the importing SVS way :devil: and the MJ acoustics sub range.
  4. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Would the MJ Refference 100 be a substantial step up from the REL Q50 in terms of quality, control and extension ?
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No - the Q50 was an excellent sub in it's day and was a worthy winner of it's five star accolade from every magazine.
  6. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Ah righto, so what would be a suitable successor to the Q50, bearing in mind my room is about 14ft x 16ft ? Buget is up to about £350, and to be honest I'm tring to get away from a black box if possible but not at the expense of quality or sound.
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    If you want something compact I can't think of anything but the BK sub fitting the bill at your price point.
    If you are going to take up Hayes offer to visit Tunbridge Wells for a demo of the Gallo speakers you will probably hear them with the Gallo sub. AV-Sales are also Velodyne dealers so you will probably be able to listen to the CHT-10 which is larger than the Gallo sub but will probably be able to significantly outperform it at a cheaper price.
  8. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    The KEF PSW2500 isn't too far off the performance of the BK, and is much better looking, not too bad with music either.
    It also has a bit more power than the BK which you may be able to benefit from with your room size. Available in some nice finishes too I believe.
    I lived with one happily before I got the SVS bug :devil:
