Great HTPC Mobo, CPU & Mem bundle at dabs
Discussion in 'Home Entertainment Computers' started by Daveybryce, Jun 12, 2008.
  1. Daveybryce
    Daveybryce
    Feb 18, 2008
    2,347
    116
    Wokingham
    +609
    Got this on a dabs newsletter.
    780g/HD3200 amd chipset Mobo, X2 Dual 2.8Ghz cpu and 2 x 1Gb XMS2 Corsair DDR2 800Mhz memory.
    Check it out
    http://www.dabs.com/bundleview.aspx?quicklinx=4DHS&bdi=678
    Just thought if anyone was looking for HTPC build cheap that can cope with Bluray/HDDVD and 1080p mkv files this is the one for you I would say.
    :thumbsup:
  2. andymaw
    andymaw
    I got that email and was wondering if it was a good deal. My main concern with it is that the processor is not one of the energy efficient ones, is it? Would this mean it would run hotter and therefore result in more noise?
  3. carlito8
    carlito8
    Jun 14, 2005
    140
    York
    +16
    In theory, yes I think so, I've gone for the same motherboard but with the AMD Athlon 64 X2 4450e processor and 2gb of the corsair memory, came to just over £136 last night from scan/ebuyer with some other bits I was ordering.
  4. Richie_UK
    Richie_UK
    Nov 14, 2006
    102
    28
    +33
    Unfortunately no free shipping with this Dabs offer, so nearly £8 delivery charge (inc VAT). The same components at ebuyer are only £2 more if you select their free shipping. At least at ebuyer you can vary the components you want. If you replace the AMD Athlon 64 X2 5600+ with an Energy Efficient AMD Athlon 64 X2 5200+ it is only £6 more than the price of the Dabs bundle including delivery.
  5. andymaw
    andymaw
    Yeah, thanks for the replies, that's kind of what I thought that I'd be just as well off getting it elsewhere with a different cpu.
