Graphics settings
Discussion in 'Desktop & Laptop Computers Forum' started by chui, Jan 15, 2008.
  1. chui
    chui
    Aug 16, 2007
    331
    Nantwich
    +17
    Hello,
    I have just recently set up my pc to run through my LCD tv.
    Everything has been fine until I tried to tweak the graphics settings. For some reason it saved the settings from which I can see absolutley nothing, just a fuzzy screen. I cannot change the settings on the pc now as I cannot see anything.
    I have re-booted but nothing, just a fuzzy screen.
    What can I do to rectify?
    Thanks in advance
  2. Croatoan
    Croatoan
    Jan 7, 2008
    401
    28
    +59
    Press F8 and go into safe mode and you should be able to adjust the resolution.
    You should always use the default resolution of your monitor / tv and use the just scan option on your hdtv.
    unless your drivers support 1080i.
    Hope this helps
    Graham:)
