Graphics Card
S
StealingSociety
just a bit of advice please. the fan on my graphics card has broke but i think my dad will buy me a new graphics card. any ideas on what i shud get, prob have around £100 to play with. then how easy/hard are they to install yourself.
any help is grateful, because i need to get this done today so i can play counterstrike without it crashing from an overheating graphics card.
thanks sam
apolloa
Well, they are fairly easy to fit as long as your PC's out of warranty of course. But as to what model you can get for £100 that's worth it I'm not sure, mabey some of the other esteemed members can jump in here?:D
But if your going to go and buy one from a shop then I would say NO. You can get much better deals on line.
TEVEZ032
Get a 7600GT (i got mine 105 from dabs)
I had a 6600GT before and the difference in BF2 etc is really remarkable.
g
