Question Graphics Card upgrade time - Advice?
jezston
Hi, my radeon hd 6850 got a good run at 3.5 years, however can't handle witcher 3 and fallout 4 so its time to upgrade. I'm totally out the loop on current hardware so need advice!
Requirements:
• budget around us$200/uk£150. Can stretch a little higher if it will make a big difference, say £180.
• must be QUIET. I do audio work so don't want a hairdryer!
• support for at least 3 monitors.
• significant upgrade from current card
Thanks!
andiuk007
EntryLevel
Established Member
I'm in a similar position (Asus 6850 DirectCU), might be useful to say what cpu you have as that may be the limiting factor as to what you can get out of a card for gaming.
If it helps, although the 970 gets a lot of praise, if your only going for 1080p from what i've read it sounds like the 960 should let you run fallout 4 at decent settings (based on this link)
What does it take to run Fallout 4 at 1080p60?
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
