Graphics Card Upgrade - Advice Please
Discussion in 'PC Gaming & Rigs' started by hillster, Aug 16, 2005.
  1. hillster
    hillster
    Feb 11, 2004
    719
    Reading
    +29
    I'd like to upgrade my graphics card to try and squeeze a bit more life out of my ageing PC.
    I currently have a Nvidia GE Force 4 TI4600, the PC is a 2.4 Athlon with 1 gb ram. I can play HL2, Doom 3 pretty well but I'd like to put off a new PC purchase for another year...
    I'm looking to spend no more than £120 and was looking at the ATI Radeon 9600XT 256mb DDR ram as I can pick it up for around £70.
    Can anyone offer any advice/alternatives please?
    Hillster
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    You should be able to use a 9800pro 256. Just depends on your power supply. Also need to make sure your board accepts AGPx8.
    You could pick up a second hand 9800pro fairly cheap by now. Couldnt tell you where though.
  3. bjd
    bjd
    Feb 4, 2002
    2,538
    N. Ireland
    +477
  4. Mickus
    Mickus
    Jul 11, 2005
    3,072
    +332
  5. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
  6. bjd
    bjd
    Feb 4, 2002
    2,538
    N. Ireland
    +477
  7. Pesky6
    Pesky6
    I choose Radeon 9800Pro.
    But i can advice NOT buy 9600 series card - they a so laggy and have many problems.
  8. Marvt74
    Marvt74
    Feb 13, 2005
    618
    Manchester
    +20
    Why the 6600gt/6800 is not much more and is superior.
    Has the x800GT been released on agp that could also be a good option
  9. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    It actually is very clear cut - the 6600gt is marginally (1/2 frames) faster at 1024x768 with all the eye-candy off (and only in a couple of games) the reason for this is the GPU is running at a faster rate on the 6600gt & the data being transfered is "small", as everything is disabled, so the 128bit ram bus is not a bottle neck.
    NOW - i would assume that anyone buying a new vid-card wants better performace but not just in achieved fps, also in image quality, so you go to a higher res & turn on you AA and AF - and check the results on those setting. As you will see from any review on any site - the 6800 (with more pipes, more mem-bandwith) will always win when compared to a 6600GT & sometimes not by a small margin.
    Also note that most 6800 gpus released lately have a very good chance of being 16pipe versions with 4 disabled ones (hence they are 12) - the extra 4 pipes can be re-enabled (software hack) & you get the performace of a quasi-6800GT !!!
    Note: I own a 9800pro & it's no match to the 6800!
