Quantcast
Graphics Card to support Four Displays
Hi.
Can someone please recommend a graphics card (to go in a HP EliteDesk 800 running Windows 10) that will support 4 monitors (display port connection on monitor).
It's just for display purposes, so doesn't need to be high spec - in fact, the cheaper the better!
Thanks.
maf1970
Displayport is a bit of an unusual standard as it can drive 4 displays from 1 port by daisy-chaining the displays. So, in theory, any card with a Displayport port should do.(This is assuming the monitors have 2 ports). If not the only range of cards I can think of is the Firepro and Quadro ones that had multiple Displayport ports would only be available second-hand / refurbished now.
examples -
GT 1030 card
Quadro P400 card
Firepro W2100 card
Peeej
What CPU do you have does it have discrete graphics? You could potentally run two from the on board and two from a GPU, most GPUs will do dual screen without gettting a high value one...
Similar threads
