graphics card software issue for TV as computer monitor?
Discussion in 'LCD & LED LCD TVs Forum' started by rogbngp, Apr 28, 2019.
  1. rogbngp
    rogbngp
    Mar 30, 2019
    14
    Edison, NJ
    I just recently started using a TCL 4K UHD tv as monitor for a HP desktop computer. I'm having some issues when I watch YT or FB videos. The color is washed out most of the time, although occasionally it looks normal.
    I don't experience the problem when streaming tv content. A computer game I play looks fine. Photos are good. Websites look normal. The problem is occurring just when using the computer and a video is featured.
    • computer is HP Pavillion 4CE4190DKN - user guide, specs (The graphics card is a AMD Radeon HD 8330 (combined with the processor) and the Audio Codec is Realtek ALC662.)
    • TV is TCL 43S405.
    I use a very simple Amazon Basics adapter cord that converts DVI from the computer to HDMI on the tv. Maybe I need to buy one that has fancier conversion?
    I have Windows 10. When I try to adjust the AMD graphics card by right clicking the desktop and opening "AMD Radeon Settings" nothing happens. When I right click the desktop and open "Display Settings" I get the annoying simple Windows 10 interface rather than it directly opening the actual graphics card UI.
    Any suggestions about how to solve this?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,904
    Lanarkshire
    +2,594
    Try accessing your graphics card properties via Windows control panel.
  3. rogbngp
    rogbngp
    Mar 30, 2019
    14
    Edison, NJ
    Thanks, doesn't work. I've tried it via device manager. C drive programs. It doesn't open.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,554
    2
    In a secret location with Jennifer Lawrence
    +11,953
    Sounds like you need to reinstall the AMD software.
  5. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,900
    Norfolk
    +2,536
    When you say 'streaming TV content' are you talking about other websites like iPlayer/ITVHub/All4 or are you talking about using the TV's own operating system (the Smart TV system)?
    Although if the control panel isn't opening then that making sure the drivers are installed properly is a good starting point.
    Grab the driver from the AMD or HP website, uninstall the old one then after restart run the driver installer.
    If that doesn't work then you can also try running the AMD Cleanup Utility or Display Driver Uninstaller after you uninstall the drivers.
