Graphics card help?
Discussion in 'Desktop & Laptop Computers Forum' started by mambojambo, Jan 30, 2005.
  1. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
    i`m planning on setting up a htpc but as i`m not sure yet if its going to be the way to go for me i want to make as little outlay as possible
    i have a pc here that is going to be my test subject
    i know its not top spec but its only to see if we get on with a htpc
    amd 2.1
    1GB Ram
    240GB HDDs
    2x Pioneer 108s
    nvidia geforce2 mx/mx 400
    (using a trial version of MSE media center 2005)
    displaying on screenplay 4805 on 8' screen
    as far as i can see only the graphics card is letting me down so whats my best option for a max of £100 :smashin:
    any ideas hints etc wanted please :thumbsup:
  2. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
    nobody got any ideas?
  3. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
  4. Kahless725
    Kahless725
    You can get e 9700 Pro which will be much much faster for £93 from www.overclockers.co.uk only trouble is its not fanless like the 9600XT but I find em pretty quiet.
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    A humble 9600 SE is more than enough for an HTPC in my experience. :)
  6. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    I'm a little confused by all the 9600 part numbers, which is the cheapest one with a heat pipe heat sink..?
  7. phasmax
    phasmax
    Hmmm, I'll be typing forever to explain all the different 9600 models.
    Basically (in order of power)
    9600
    9600 Pro
    9600XT
    Just search for radeon 9600 and the cheapest one - grab that. I tend to stay away from "SE" versions though - they are really cut-down versions...
    Then again, you don't need graphics performance for games, now do you :)
    I have a normal 9600 256MB. Then again, I could have had one with 128MB memory and it wouldn't have made a different. A normal 9600 (with passive cooling) is FINE.
    Just note - as far as I'm aware, a lot of 9600 PRO graphics cards have fans on them.
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    AFAIK the one I posted the link for is the cheapest fanless 9600 .. it doesn't need a cooler-pipe system since it doesn't generate much heat, it uses a simple heatsink and works very well.
  9. zAndy1
    zAndy1
    Nov 26, 2002
    19,358
    2
    5
    163
    +6,482
    Is a 9600 card good enough for use with MCE 2005 as doesn't MCE use VMR9 exclusively (at least for it's dvd playback anyway) and doesn't that therefore mean that it'll struggle?
    Andy
