Graphics Card for under £80 (single-slot)
muddyfox470
Ok Guys.
I got an X1900GT with HDCP and was nice and quiet and cool, however it was fussy and didn't like my motherboard at all. So have had to get rid of it.
So I'm looking for a graphics card that is single slot, quiet (which unfortunately rules out 8800GS), and has full HDCP support and ideally onboard HDMI processing (so I can use a DVI-HDMI adapter), i.e. onboard cheapo sound unit so I can link it to my TV via HDMI cable :rolleyes:
Single slot and Quiet are my main priorities as I've got a fairly good pc set-up at the moment in my SFF case.
My monitor is a 22inch 1680x1050 jobby, and I will be using it for gaming (I like everything turned on full at the max. resolution) but only play Steam, BF2, BF2142, IL2:Stumovich and will be using it for HD DVD playback, so if it takes the load off my CPU then thats a good thing :juggle:
PC atm (ignore sig)
E4500 @ 2.5Ghz
2Gb PC6400 RAM
Abit N73HD Motherboard (onboard HDMI)
Hiper Type-R 580W PSU
I don't mind waiting a bit, I know the 8800GS are stonking value for the price but they are a bit noisy from what I have read. I did have a 8800GT for a brief time and although it was a bit too expensive and over powered for me at the time, it did run cool and quiet :) (again single slot)
Cheers :bowdown:
PS. I ideally want to spend less but want something on par with or better than an X1900
namuk
Ok Guys.
PC atm (ignore sig)
E4500 @ 2.5Ghz
2Gb PC6400 RAM
Cheers :bowdown:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-034-GI&groupid=701&catid=56&subcat=1008
or
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=772608
sorry mate last is duel slot
