graphics card for pure decoder ?
Discussion in 'Microsoft Windows' started by homethx, Jul 2, 2005.
  1. homethx
    homethx
    Feb 24, 2002
    728
    +78
    what's is the best card from nvidia for pure video decoder must be <£100 passive cooled on agp socket for use with a sony hs20 projector on dvi connector
    Will geforce 6200 do the job I'm using ati 9600xt ultimate at the moment
    what benefits will i gain if I do change better picture quality smoother picture on freeview,dvd playback ?
  2. HSC
    HSC
    Nov 23, 2004
    1,984
    63
    Coventry
    +172
    i believe the 6200 will do purevideo but accoring to this link only the PCI-E version.
    http://www.nvidia.co.uk/page/purevideo_support.html
    you'll have to go for a 6600 card minimum if you need AGP - but you should be able to get one for £60-£80 (try gigabyte if you need passive cooling)
  3. homethx
    homethx
    Feb 24, 2002
    728
    +78
    Thanks for that 6600 it is then :thumbsup:
  4. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
  5. homethx
    homethx
    Feb 24, 2002
    728
    +78
    Like HSC said they dont work with pure decoder shame that . So it's a 6600 gigabyte for me.
  6. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    As far as i can remeber all 6 series cards support pure video, the 6 series chip was designed as a PCIe chip only later updated to support AGP through a conveter chip to convert the PCIe signal to an AGP signal that’s why the AGP cards are a few pounds more than the equivalent PCIe card
  7. homethx
    homethx
    Feb 24, 2002
    728
    +78
    OK I may have to investigate this first if it's true Even cheaper card :clap:
