Graphics card for HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by jhkanguk, Dec 6, 2004.
  1. jhkanguk
    jhkanguk
    I just ordered P4 3.2G 512MB PC.
    It comes with ATI RADEON™ X300SE with 128MB video memory. (PCI Express)
    I plan to use this pc for upscaling to DLP tv, using ffdshow probably.
    I believe the cpu speed is good enough. Then does graphic card affect post-processing within ffdshow? Is any graphic card with DVI ok or the faster the better?
    Which PCI Express graphics card do you recommed? I don't want to be limited by graphics card when using ffdshow.
    Thanks in advance.
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    The card you will have will do just fine in a HTPC on the display side and the proc is ok for scaling. :smashin:
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    If you're using the VMR renderer then the more powerful a GPU you have the more you can apply AA and AF, just as you do for games, which also improves PQ for video material as well as 3D games.
