Graphics Card Diag Program
Discussion in 'Computer Components' started by H4r7y, Oct 8, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    is there any program i can get hold of that will show me the speed etc of my graphics card? to see temps, mem speeds, core speeds, voltages etc?
    :lesson:
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    powerstrip does it, doh!
    all sorted now then
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    If it's an Nvidia,you may also find RivaTuner helpful from the O/C point of view as well as diagnostics.
    Works very well and overclocked my 5900XT very nicely.
    http://www.guru3d.com/rivatuner/
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Ok...still may be worth a look as it has some support for them.
  6. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
  7. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    According to the site,yes....found the following...
    Added ATI RADEON 9500 / 9500PRO / 9700 / Fire GL X1 / FireGL Z1 low level support. Now RivaTuner can diagnose and overclock these graphics processors.
    Added SoftR9700 patch script for Catalyst 6.200 - 6.255, which allow you to enable software locked 8 pixel pipelines on RADEON 9500 based boards and turn any 128-bit RADEON 9500 into RADEON 9500PRO and any 256-bit RADEON 9500 into RADEON 9700PRO.
  8. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    i dont think its gonna work with the 9000 thogh mate, its a bit of an oldie
  9. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    I know what you mean there....until I bought Doom3 and Warhammer,I was fine with a really slow GForce5200....then I found that for anything other than 2fps I had to have something better....still,a good excuse to upgrade!
  10. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    its been a while since i did upgrade my pc.
    touch wood and all the stuff ive got to put in it will give a decent performance hike
