Hi Folks,
I have just aquired a second hand small form factor PC that I am planning to use as a HTPC. The plan is eventually to attach it to a remote backend but for now it will be standalone. Its a P4 2.8ghz with 2GB of Ram and now has a 320GB HDD in it.
I am more than pleased with it except for one thing. The graphics card.
I got this particular PC because I saw it had what looked to be a full size PCI slot in the back. I will initially hooking this up to my CRT TV so wanted to drop a graphics card into it with an s-video ouput. The problem is the amount of space that is available for the card. It will take a full height card but only one that is a maxiumum of 135mm in length.
So.................
Does anyone know of a PCI (not pci-e) graphics that has a tvout and is less than 135mm long?
I would settle for one that has a DVI port as I plan to buy an LCD TV soon anyway.
J
So.................
J
