Graphics card advice needed
Discussion in 'Computer Components' started by Roy37, Jun 14, 2015.
  1. Roy37
    Roy37
    Feb 20, 2009
    98
    Need a new graphics card as my NVIDIA GeForce GTX460 appears to have packed up as my computer crashed saying there was a driver issue, went to black screen and crashed. Device manager now says "windows has stopped this device because it has reported problems. (Code 43)". I've tried updating drivers but no success.
    I need to get a new one asap as my screen resolution was 1920x1200 but now the max I can choose is 1600x1200 which is just hopeless.
    Can someone recommend a decent graphics card that won't break the bank? I don't do games, but I do use photoshop and watch a lot of films/tv, I like my screen resolution 1920x1200. Given that this card is only a few years old I'd be reluctant to have the same make again, I'd prefer a more reliable make.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,620
    2
    In a secret location with Jennifer Lawrence
    +12,060
    What make is the one that you currently have? What's the spec of the rest of your PC?
    Have you completely removed the graphics drivers and reinstalled?
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,932
    Norfolk
    +2,548
    Both frequently don't use the graphics card to any significant degree so the first thing I'd try is taking it out and using the onboard graphics that almost all PCs contemporary with a GTX 460 will have.
    You might want to specify what make the card is then.
  4. Roy37
    Roy37
    Feb 20, 2009
    98
    Sorry, I just assumed that NVIDIA was the make, that's all it says is NVIDIA GeForce GTX460. How do I find out the make?
    PC details are:
    Windows 7 Home Edition 64-bit
    Processor: Intel Core i7 CPU 950 @ 3.07 GHz
    Installed Memory (RAM): 12.0 GB
    4 Hard drives (a very small 60GB SSD for the Operating system and main programs, and 3 x 3TB drives), all showing red as they're full up.
    No I didn't completely remove the drivers, I just updated them. I will try removing completely and see how I go.
  5. Greg Hook
    Greg Hook
    Nov 25, 2001
    24,620
    2
    +12,060
    Either open the case and have a look or probably easier is to download a free program called GPU-Z and it will tell you there.
  6. paulktreg
    paulktreg
    Feb 27, 2011
    940
    46
    Clitheroe
    +131
    You say your hard drives are full! How full especially the SSD? You need a certain amount of free space for your Windows and games to run correctly.
  7. Roy37
    Roy37
    Feb 20, 2009
    98
    The SSD has 3.12GB free
  8. Roy37
    Roy37
    Feb 20, 2009
    98
    Just opened the case (wow! there was a lot of dust in there to hoover up), and it says PALiT on the graphics card so I'm guessing that's the make??
  9. Roy37
    Roy37
    Feb 20, 2009
    98
    Would've tried a system restore but for some strange reason all my restore points have disappeared.
  10. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,932
    Norfolk
    +2,548
    Yeah, Palit are the card manufacturer.
  11. Roy37
    Roy37
    Feb 20, 2009
    98
    I can't take it out as there will be nowhere to connect my monitor to, the monitor connects to the graphics card and there is no other connection for it unfortunately.
  12. Roy37
    Roy37
    Feb 20, 2009
    98
    Tried several times to do this but I don't think it's all getting removed, and when I try to install I get "Access Denied".
  13. n00bftw
    n00bftw
    Jan 1, 2015
    3
    4
    north west england
  14. scythefwd
    scythefwd
    Dec 3, 2014
    150
    Virginia, USA
    +13
    Not to be insulting, but are you running the install as an admin? If you check the security log in event viewer, are you seeing any notifications in there that raise suspicion?
