Graphics card advice needed
bohemian
Can anyone recoment a decent graphics card that is compatible with this motherboard?
Asustek computer inc
CM6330_CM6630_CM6730_CM6830
REV x.0x
I have 8GB memory & intel core i7 3770 CPU @ 3.40GHz.
brookheather
Any PCIe graphics card will work - it just depends on how much you want to spend and what sort of games and settings you want to play at. What power supply do you have as that will possibly limit use of higher end cards.
bohemian
pcu is 350w, i have been running Microsoft Flight Simulator X, graphics are pretty smooth but crashes after 5/10 minutes play
brookheather
What is the specific model name of the PSU? Is it a high quality one or a cheap one bundled with a case? You will be limited to a lower end graphics card such as an HD6670 or similar card which doesn't need a 6-pin power connector.
Similar threads
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
