graphic card question
Discussion in 'Desktop & Laptop Computers Forum' started by fatrich, Aug 21, 2002.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    hi
    at the moment i have a radeon ve card which i run on my barco 808 (with the help of powerstrip) at 1280x720 resolution , i have had this card for 6-8 months and am thinking of upgrading to a radeon 8500 or something similar, can anyone comment on this card in regards to improvements over the existing ve card and any other alternatives.
    The htpc is used purley for dvd playback (no tv in or o.ut) but i am thinking of using it for games as well.
    Dont want to upgrade if it only improves picture quality by small amount.Finally would buying an OEM version of these cards be an issue with any of the current ati drivers.
    currently using windows Me.
    any advise would be appreciated
    regards
    richard
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I am in the same situation, running Radeon VE @ 1368x1024, but I think we shoudl upgrade to new Radeon 9500 or 9700 once in becomes available (probably September).
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Overclockers are doing the ATI ALL-IN-WONDER® Radeon 8500 DV 64MB for £139.00 + VAT
    Seems a pretty good deal to me! ;)
    Overclockers
  4. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    cheers guys
    but its not a money issue, i can get the 8500 fronn ccl for £134.00+vat, its more a question of performance and how much better than my ve is the 8500 or the 9000.
    The 9700 is not on this planet, it look absolutly unreal at an unreal price i might add
    cheers
    richard
  5. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    Hi Rich,
    Did you know about the broken gamma with the 8500....well ATI fixed it with their new catalyst drivers, the problem now is the hardware acceleration doesn't work.so be aware.
    The dvd playback on the 7200 7500 use the same "engine" 10 bit dacs etc etc, the 7200 is what i have it's got no fan,the 7500 uses a fan so does the 8500.
    Don't know much about the VE cards but i suspect they are the same as well.
    If you play games as well go for the 8500 but remember the hardware accel' problem.
    If you must update go for a pukka retail made by ATI card due to driver issues with some oem cards although there is a work around for this.
    Personally i'd wait for the 9xxx cards to be main stream but again wait for the drivers to "mature"before jumping in, too many people had their fingers burnt with 8500 debacle.
    check this scroll down to graphics cards & have a read.
    Tim
  6. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Hi Tim
    cheers for the info, i think i will wait till the 9700 comes down in price and also like u mention the driver issue, how the 1095 doing? teamed it up with a tag yet?
    catch u soon
    take card
    rich
  7. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    Hi m8 the mating happens sunday week can't wait although my Yammy has now got to be sold :( & my mrs has got the major hump i feel that it's worth it ;)
    Tim
  8. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Tim
    Just read that radeon thread and im shagged out it was huge, so how good is the radeon 7200 and which driver are u currently using?
    regards
    richard
  9. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    Hi Rich,
    Because i use Theatertek, i use the 6025 for win 2k or 7093 for win 9xx drivers.
    Can't fault the card m8 cost me less than 60 quid (last xmas) the picture is superb.
    What's wrong with the ve?
    Tim
  10. Jenz
    Jenz
    Nothing. Personally I wouldn't change this card at the mo'. Particularly if you are using the DVI socket.
  11. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    There you go Rich i knew there was someone who was using a VE Radeon, if it's good enough for Jenz it's good enough for us mere mortals;)
    What drivers do you recommend Neil for the VE?
    Tim
  12. Jenz
    Jenz
    Standard TT recommended Drivers :D
  13. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    thanks Neil
    look like i will hang on to the ve a little longer, wot do u think would be a good replacement for the ve in the near future?
    cheers
    richard
  14. Jenz
    Jenz
    Well obviously the 9xxx series cards are the ones to look at. The thing is that I'm beginning to question just how much better I can improve the existing setup by changing the graphics card alone. I'm not convinced I will get bang for the buck by doing this.
    So I'm gonna experiment with the H3D card, Component and SDI.
    Right now I'm just enjoying films :)
  15. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Neil
    i would be interested in the results, the sdi card option seems quite popular at the moment, i believe jeff has an sdi modded dvd player, i am not up to scratch on the sdi cards but i am let to believe they are quite expensive.I like u use the tt player but would like to improve the overall picture quality if i were to use the sdi card wheres the best place to purchase one and how would i intergrate it in to my system (i use htpc for dvd playback and not a standalone player)
    all advise would be greatful
    thanks
    richard
  16. Jenz
    Jenz
    A cheap SDI Modded Player from mainland Europe is going to be £500 based on a Panasonic body.
    A more expensive one is going to be around £1,000.
    The SDI Card for PC is around £550.
    Neil.
  17. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    can any one explain exactly wot exactly is an sdi card and how does it work? and if i had a sdi modded standalone player would i also need an sdi card in my htpc and wot are the benefits.
    forgot to say please and thankyou
    richard
  18. Zone
    Zone
    Jun 24, 2001
    6,813
    Barnsley
    +2,573
  19. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    thanks Zone will do some reading
    cheers
    richard
  20. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Richard,
    If you are using the VGA output on the VE, then consider removing the filters. Worth the effort for use at higher resolutions for you CRT guys.
    Here is a good link
    If you want the mod doing, I have the surface mount desoldering tools etc, and lots of tweaking experience,
    cheap service for forum members ;) :D
    Mark.
  21. Jenz
    Jenz
    Mark drop me a PM with the price of the mod :)
