graphic card problem
rockyclown
hi
wondered if any body could help.just fitted nvidia gt520 graphics card to my h61 motherboard with i7 2600 intel processor,all ok however the fan on the motherboard/processor doesnt run and overheats,when i removed the graphics card the fan runs fine again, cant understand why the card would disable the fan,is there something im missins?thanks for any help
JDCFH
rockyclown said:
hi
Maybe your psu isn't up to the job of running the card thus why your fan stops when it's installed?
Miss Chief
520 card probably doesn't need a separate connector so it should be fine. Check your connections and if the 520 requires a separate power connector?
rockyclown
wow jdcfh
think you nailed it,had my pc built locally,for a very reasonable price considering the specs,obviously the savings were on things like the psu,found an online power calulator and my psu at 120watts is nowhere near powerfull enought,miss chief thanks for your post,your correct :clap:the gt520 doesnt need a seperate power lead,many thanks
JDCFH
rockyclown said:
wow jdcfh
No problem mate - never scrimp on your psu.
EndlessWaves
wow jdcfh
120W? Generally that capacity is reserved for specialist mini PCs, many of which won't even have a slot for a card. If he was going to scrimp on the PSU chances are the rating would be 300-500W as they're the cheapest because they're produced in far bigger numbers.
Are you sure you're not just reading the capacity on the 3.3V/5V line or something?
rockyclown
endless waves,just re checked yes your right that is the low voltage output,it is a 450 watt,so that should be strong enought and not cause the fan not running problem?ive spent hours on google and have never seen mention of this before and at a bit of a loss unless 450w is not enough for the dvd drive, processor and graphic card to run together,but if so why just effect the fan?thanks for any suggestions
EndlessWaves
I think a single low power component not running at all is unlikely to be caused by a power supply issue, you'd either expect it only to stop running at higher loads or, more likely, the system to become slightly unstable generally.
I'd check the manual for the motherboard to see if that had any mention of this behavior and if not send an e-mail to the motherboard manufacturer and ask them what's happening as just the single fan turning off with no other symptoms does sound like it might be intended behavior for something.
rockyclown
thanks for your help everyone,i got an email from the card manufactuare this morning,they said not compatable probably and to update BIOS,im going to change the card anyway to an upgrade,so could anybody suggest a card for 100 to 150 pounds thats they now works with asrock h61 motherboard.many thanks again
'probably' and 'bios' are not not very helpful comments from them. The card being faulty is more likely - in fact I cant think of a single reason (without making something implausable up) why the bios has anything to do with the GPU.
Did you have this card in your system already and suddently things dont work, or is it an upgrade as such that you have done yourself?
jellofund
As Theydon suggested in your other thread a 560ti would be a very good card if you have a budget of around £150. Although I think the HD7850 in the classifieds (£160?) is well worth considering too but it depends how flexible your budget is and if you're happy to buy privately rather than from a retailer.
I'm sure someone here will be able to confirm for definite but I have some doubts that your 450w PSU would be capable of powering either card, especially if it is more of a budget brand (wattage is only one part of the equation). At a guess a good quality 550-600w PSU might be more realistic.
I guess the first thing to establish would be whether or not you are comfortable adding some cash to the pot for a new PSU if required and if you're comfortable with the idea of fitting one yourself (not too difficult and plenty of guides on youtube etc.). If you're not too keen on replacing the PSU then it'll likely mean opting for a somewhat less capable graphics card but I have no doubts the guys will still be able to recommend something that fits your requirements :)
ps. might also be worth adding a note of the make / model no. of your PSU.
rockyclown
been overwelmed by all the help with this problem,ive decided what to do now,return the 520 card for full refund as i only bought it 7 days ago ,i called the shop who built my pc for me 2 months ago so under guarantee and they have a 560ti that they will fit,so if any problems still and a motherboard fault they will have to sort(i havnt told them about me fitting the 520 and fan fault)and if psu is found to be the problem i will get them to upgrade it,so although it may cost me a bit at least it will get sorted,many thanks again
No worries let us know how you get on!
Delvey
If it is the PSU causing the problem then a 560ti will most probably make it a lot worst
jassco
With it being under warranty its better to find out sooner rather than later, and best way is to strain the system a bit :)
Delvey
Of course
But the OP wants this resolved, so adding a beefier card is not going to help
Houghsx
If the system was put together by a shop which you have paid for, surely you can just hand it back to them to fix.
Just to clarify, did you actually add the card or was that put in by the shop? It sounds like a faulty m/b as no gpu should stop a fan!
jellofund
OP added the card himself after it was built (mentioned in post #13).
Clunk
Just a random thought on this. Is the CPU fan connected to a SYS fan header by any chance?
rockyclown
thanks again for the help.its been resolved now thanks.took to the shop that built it a few weeks ago they fitted a bigger psu and a 560ti which needed its own power supply rather than the 520 that caused the problem which just slotted in with no other cabling,so what the cause was is still a mystery but working great now,many thanks again
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
Trending threads
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
