Hello again, has anyone got a Grandview screen fixed to their ceiling???? If so how did you fix it ??? I know I have to find a joist and put the hook into it but what do you use all I find is stuff to fix into brick,concrete etc...... Cheers, Phil
When I fitted mine I had to nail dwangs of timber between the joists above and screwed in large hooks got at B&Q. The eyes on the screen housing hook on and the screen swings free to ensure that it hangs as flat as possible. My cinema is a garage conversion so I had access to roof above. Hope this helps.
