Quantcast
Gran Turismo Sport
KennyNinja74
While you can't tinker with the cars much, it's worth looking at the Traction Control and Brake Balance settings for various cars and in the longer races with pitstops the fuel mix too.
The default TCS3 can be quite a drag on your times, I find dropping it to 2 is almost always possible and with the FWD and 4WD 0 is simple enough to drive. Some of the RWD cars can be quite twitchy though and spins are a real PITA with a wheel as the game takes ages to reset you and 3 point turns are no fun at all.
The brake balance can make quite a difference too.
BTW those settings seem to reset to default on non-owned cars when you're doing other things so worth checking each time before the start line.
I always have TCS set to 0. It was tricky at first well worth the pain in the end. :D
Here's a few Brake Bias reference points i use as a base starting point.
Gr.3
MR = - (1-3)
FR = + (1+3)
Gr.4
MR = 0 +3
FR = +2, +4
4WD = +5
FF = +5
Lancia34
I still can't get on with TC on 0 for most cars except 4WD and a select few others. I stick TC on 2 and can be pretty competitive most of the time. I have adapted to only having TC kick in at certain times where it helps and can feather the throttle and keep the sliding to a minimum so it doesn't kick it at other times.
Maybe as and when I replace my G29 with a shiny Fanatec I'll be able to sort TC out :)
KennyNinja74
I'm a lowly a pad peasant. :laugh:
AMc
TBH I'm usually on 2 but sometimes 1 depending on the vehicle - the exception being the 4WD which I can cheerfully charge around with all 4 wheels slipping :).
I find the diifference between 3 and 2 is noticable but it doesn't make most cars so twitchy I'm spinning all the time.
The problem (for me) is that if I miss the fact that I've started to oversteer out of a corner then applying enough counter steer, fast enough is tricky - if I don't manage it and spin then getting back to the track and pointing the right way is so slow that I've basically lost any chance in the race.
I think that's a big issue on a wheel that isn't so bad on the pad - as you can just flick full opposite lock in a thumb twitch. Likewise when you're in the weeds on the pad it's quicker to rejoin.
My least favourite thing is ending up with the wheel at an unknown angle, trying to work out which paddle to use to get back to reverse :blush:
Oh but if you can train yourself to watch the ABS light out of the corner of your eye that's a great alert to the fact that things are going sideways before you necessarily notice the tyres complaining. ;) I usually see it ... too late.
Eddy555
I spent the evening recovering my SR ranking back to S again and had some cleaner races to boot. Still got a DR of D when I was B before, but maybe I am just getting slower. Or maybe it's the Lexus. Either way the Grp 4 race at Spa is great, but needs to be longer.
Didn't like the M3s at Suzuka, and the Dallara at Barcelona is good but I'm really not used to that car.
D
Deleted member 837986
What. A. Game. Had about half a dozen Gr4 daily races this evening around Spa using the Mitsubishi Evo. Think my best finish was around 10th/11th out of 16 but I thoroughly enjoyed it and cannot wait to get on again soon.
Just need to learn to stay on the track as those penalties were killing me!
Habanero
I find it takes several races to rise up the rankings, but you can drop down in only one. Last week I was B/B but one Gr3 race at Interlagos which had a chaotic first lap saw it dive to D/E.
KennyNinja74
What....one race and you tumbled down to a D DR? that's savage.
AMc
I'm perpetually on SR S but DR D. I bounce along the boundary of moving up on DR but I don't get enough time to qualify and then consolidate good final positions for enough time to stay up if I make it.
I don't find it too bad as long as I keep my S so the worst rammers aren't in the same races.
I really disliked the M3 race. I was reasonably fast and was coping with the tail happiness but in the couple of races I tried I just kept getting nudged from behind by cars that then pushed through then I got penalties for exceeding track limits :confused:
Lancia34
If you are SR S you should be able to up your DR to at least D quite easily. Even starting at the back and just keeping it clean and take no risks. Usually others will spin off or mess up and you can take places.
Best tactic is to not fight any challenges too hard, it's fine to let people through sometimes.
Oh and if you keep getting nudged form behind then just go off the track slightly and they will get a penalty ;)
AMc
You'd think so wouldn't you? ;) It seems I'm quite erratic.
Looking at my history - ironically between races 40-60 I appear to have been driving like a bit of an arse and yet I was getting better places :eek: :blush:
Perhaps I should let mr SR plumet and go and play in the banger races 🤣
You can see the last few races were 2 laps of the Nurburg ring - which were messy for a bit but drop outs and spinners and some genuine racing, so I made places. I was quite polite too.
You can see the impact of a couple of those M3 Suzuka races yesterday - knocking down my SR and DR.
My brief pop into the level above was when I got time to set a sensible qualifying time and then lead from the front.
Biggest problem is I don't get long sustained time to race - so I drop in on whatever looks like fun and end up in a squabble with other casual racers with no qualification times.
I never find the penalties compensate enough for the harm done. Avoiding people messing up yesterday I got track limits penalties - when I was punted I saw them get 3-5 seconds but it cost me a hell of a lot more than that to rejoin.
Lancia34
Same problem I have, only maybe 90 minutes once or twice a week so I tend to pick the races that I have always enjoyed and done good at such as Interlagos, Suzuka etc...
I have raced them so much that i can set a decent qualy time in a few laps and then have 3 races or so in a session. Unless I happen to have loads of time I tend to stay away from any races I haven;t done much of so never do Daily A and rarely Daily C.
Maybe over Xmas you can put a bit of time into getting some good qualy times? I'm hoping I get a bit of time to play a bit more as I love a good few hours racing :)
AMc
No, no chance at Christmas. My partner works away for some nights in the week so I get a couple of hours here and there when the kid is in bed. If I stuck to GTS then I could do more but I also play RDR2 with some old gamer friends.
I guess I'll just have to live in DR D and not worry too much ;)
furryhobnob
furryhobnob
AMc
@Eddy555 nice race around spa. I’d never have caught you without that track limits penalty but then spannered myself trying to get another fraction on that corner glad I didn’t take you out.
btw the other guy apologised for tapping you but you’d already gone.
lots of fun at spa!
Eddy555
No worries, I had come to a big stop to try and avoid hitting you so I'm not surprised he hit me but no harm done.
The first lap I was struggling to get into the groove for some reason, and took a while to settle in, even after putting in my fastest qualifying time just before the race.
Those track limit penalties always get me
Similar threads
Trending threads
Latest News
Disney+ UK launch now 24th March
  • By Andy Bassett
  • Published
LG Filmmaker Mode will use autosensing
  • By Andy Bassett
  • Published
Hisense U8Q and U7Q QLED TVs coming to UK in 2020
  • By Andy Bassett
  • Published
AVForums Podcast: 20th January 2020
  • By Phil Hinton
  • Published
Hisense abandons OLED TV models
  • By Andy Bassett
  • Published
