Gran Tourismo 4 - BUG ?
Discussion in 'Nintendo Forums' started by Dr_Mike, Mar 8, 2005.
  1. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    379
    Loughborough
    +16
    Got my copy of GT4 today, pre-ordered from GAME.
    Either I'm being stupid or the options menu is bugged. The cursor skips straight to the exit options button and you can't move it back to select screen setup etc. :mad:
    Otherwise, seems good, seems to have more sense of speed than GT3, even in slower cars, the in car view seems to be lower to the ground although this may be because I can't select the correct aspect ratio of my 16:9 TV. Can't switch to the chase view either for some reason, although I don't normally use it. Driving feel is quite different from GT3 as well, cars slide around alot more, even with the driving aids on.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,568
    Canterbury, Kent
    +1,219
    As i don't own this game(but have had a quick play), but iirc you just press the select button to cyle through the views available, 3 of them i think(bumper, bonnet and follow). But i must point out that this was on Arcade mode not GT mode.
  3. nero0410
    nero0410
    Jan 5, 2004
    12,702
    Weston Super Mare, UK
    +5,051
    I havent had this problem. I picked mine up last night at the midnight opening and have played it for quite a few hours, changeing options etc.... and not had any of those probs.
    It may be an idea to take it back and get an exchange for another one.
    tris
  4. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Bit off topic. Does the PAL version have 480p and 1080i in the screen selection menu?
    Matt
  5. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    379
    Loughborough
    +16
    Well I've managed to get into the options menu now by some fairly random button pushing. Not ideal, but servicable. I have manged to change the camera view by pressing the correct button :blush: rather than assuming it was R1 as in GT3 (note to self :rtfm: )
    The UK version doesn't appear to have any prog scan or hi-def options :( . The screen menu has only got aspect ratio and V&H offset options.
