Grambo's New Living Room Setup
RamboGrambo
Been a long time fan of the forum and thought I'd share my living room setup.
If you have any questions please ask.
LG88
Really nice pal. Looks so clean. Love the lighting in the roof.
What tv is that?
markb1980
Love this. I have the same unit in black. Can I ask what are the names of the two greys you have used on your walls?
RamboGrambo
SPECS
  • KEF: 2 x T101 (Front Speakers), 2 x T101 (Surround Speakers), 1 x T101C (Centre Speaker), 2 x Ci160QR (In-Ceiling Atmos Speakers), 1 x T-2 (Subwoofer).
  • Sony: STR-DN1080 - 7.2ch Home Theatre AV Receiver.
  • Samsung: QE75Q9FNAT - QLED 4K TV , 1 x WMN-M23EA/XC (No Gap Wall Mount).
  • Microsoft: Xbox One X.
  • Virgin Media: 2 x Virgin TV V6 Boxes, VIVID 500 (V.VIP)
  • NVidia: Shield TV.
  • Logitech: Harmony Elite , 1 x Harmony Precision IR Cables.
  • Philips: 1 x Hue Smart Lightstrip Plus Starter Kit - 2m, 5 x Hue Lightstrip Plus - 1m Extension, 6 x Hue Ambience Dimmable LED Smart Spot light, 1 x Hue Dimmer Switch.
    Google: Google Wifi, Google Hub.
  • Nest: Learning Thermostat.
  • TP-Link: TL-SG108S 8-Port Desktop Gigabit Ethernet Switch.
DLxP
Love this. Really nice design - top work. Did you get a pro in to do that ceiling?
May I ask what wall unit that is?
RamboGrambo
Local Contractor made the ceiling from my Design as the Philips LightStrip had a Maximum length of 10 Metres, so made the ceiling 2m Squared and Linked 8 LightStrips together.
Units are 2 x Ikea Besta with Gloss Doors.
Darrenraymond
Very nice mate and thanks for sharing the selection of paints used.
I'm currently in the process of gathering things up for my own living room re-vamp and urban obsession is just what I'm after.
p.s - that TV is the dogs mate :thumbsup:
DeepDiver
Was the chimney breast already there or was it built to accommodate cables?
What size amp, & does it fit. Do you have any air circulation in the besta?
Nice & neat.
RamboGrambo
Chimney Breast was already there, but needed to be extended both sides to accomodate the 75" TV and Speakers as the previous TV was only 65".
The amp is a Sony STR-DN1080 and is (430x156x331mm) in dimension. It fits but is snug, this along with the Xbox One X and Samsung One Connect box for the TV put out alot of Heat, so I have holes in the bottom of the 2 extensions so the Heat can rise up and come out through the gap in the lowered ceiling where the LED strip lights are, Its not the tidiest but it works.
Silverblack
Sleek and clean setup!:smashin:
NASAKillbill
View attachment 1152023 View attachment 1152024 View attachment 1152025 View attachment 1152026
View attachment 1152027 View attachment 1152028 View attachment 1152029 View attachment 1152030
View attachment 1152031 View attachment 1152032
Hi mate. Loving the build the vibe. How did you get the Philips light strips wired up for celling/power?
RamboGrambo
New Socket was installed behind false wall, higher than normal as the lightstip lead wasnt very long. A switch was also added to allow the socket to be turned off and on from the outside easily. (you can get your hand in the cupboard and up the wall but its awkard)
Lightstip power supply was then plugged into the socket and fed up the wall into the false ceiling, just close enough to meet the first Lightstrip.
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
