Grainy picture on Sky+
Discussion in 'Sky Digital TV Forum' started by Dre, Dec 23, 2003.
  1. Dre
    Dre
    Dec 18, 2002
    114
    London
    Just had sky+ installed via the £99 + £1 offer...great...aoart from the cowboy installer...anyhow the picture quality on this box (v1) seems to be grainier (or should that be more grainy) than my previous grundig box. Is this something anyone else has come across and resolved? Any help appreciated.
    :clap:
  2. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    Could be to do with that the Sky+ boxes come with an RGB convertor built in which would hence the clearer sharper or grainier picture.
  3. jakefraser
    jakefraser
    You sure it is set to RGB?
    Sky boxes by default are set to composite.
    Go to services, 4, 1 and make sure one of the options says RGB.
    Jake.
  4. Dre
    Dre
    Dec 18, 2002
    114
    London
    Box is set to RGB...I've checked the cabling and the finish is poor to say the least. I've tidyed it up a bit and the picture quality is much better...I have called sky to get an engineer to fix it properly
  5. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    Did you used to have an RGB convertor on your old box???
  6. Dre
    Dre
    Dec 18, 2002
    114
    London
    No RGB converter used...
