Grainy picture on Mikomi 20in LCD
Discussion in 'LCD & LED LCD TVs Forum' started by chuckylefrek, Aug 16, 2005.
Tags:
  1. chuckylefrek
    chuckylefrek
    I have just upgraded my CRT TV to a Mikomi LCD 20in TV after reading good reviews about it.
    I am very disappointed with the picture as it appears very grainy.
    My CRT TV had a perfect picture.
    I have an aerial on my roof too.
    Any ideas why this is the case? I was under the impression LCD TV pictures were better then CRT.
    Is it a faulty TV? Or is this just what they should be like?
    I would appreciate any help as I am tempted to take it back and get a 20in CRT for 200 pounds less.
    Paul
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    get yourself a digital signal into it,lcd are very high quality pictures therefore require a good signal and analogue just dont cut it, :lesson:
  3. chuckylefrek
    chuckylefrek
    Thanks for the reply
    The picture is the same when I use my freeview box on it.
    Could it be a bad signal? Though the CRT TV Picture quality was perfect
    Paul
  4. chuckylefrek
    chuckylefrek
    If it is the signal - will a booster sort it out?
  5. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    a booster will only boost the bad bits as well as the good bits,whats it like with dvd?
  6. chuckylefrek
    chuckylefrek
    hi there
    Alot better with DVD. Guess that points to the signal being the problem?
  7. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    crt pictures are not as detailed as lcd so what is actually is a very good clear picture is just the picture noise a crt wont show up unless you have something like a top end toshiba
  8. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    best bet would be to get sky, even if its only the freeview
  9. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    The image quality on Sky wouldn't be any better.
  10. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    ????? surely a pure digital signal from a sattelite will be better than an analogue aerial picking up a signal and then having it converted a bit like passive and active speaker conversion.... open to learning :lesson:
  11. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Freeview's digital. The digital signal is received by the antenna - it's not an analogue aerial as such, I don't think. Satellite receives the signal in a similar way - just from a satellite in space instead.
