grainy and static noise on Q7F
Discussion in 'Samsung TVs Forum' started by Killermio, Jan 8, 2018.
  1. Killermio
    Killermio
    Jan 7, 2018
    110
    Westerham
    +8
    has any one ever experiences this on the unit. its on all sources. 20171208_150824.jpg
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +460
    Doesn't look good. Does it look like that on normal TV channels? If no, then it's unlikely to be the TV, so suspect HDMI cables and try some different ones. What other sources are connected?
    Regards
    Phil
  3. Killermio
    Killermio
    Jan 7, 2018
    110
    Westerham
    +8
    Yep it's on all source and if used a few different HDMI cables. Do reckon it's the the tv mother board or the processer.
  4. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +460
    Did it use to work okay and this is a recent fault?
    If it use to work okay try a factory reset, otherwise if that doesn't work it is faulty. Only after a repair and fixing it can someone say what is the actual cause.
    If it's a new TV and never worked get a replacement from the shop.
    Regards
    Phil
  5. Killermio
    Killermio
    Jan 7, 2018
    110
    Westerham
    +8
    Iv tryed factory reset sh*t no luck. Iv got Samsung coming out to look at it. They have to replace it.
    Thanks for the advice.
