GrafikEye automation controller
Discussion in 'Smart Home, Climate Control & Security Forum' started by rowlandhills, Aug 4, 2005.
  1. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    Mods, please remove this if inappropriate, but as what I'm selling is a bit unusual I wanted to attract a little more attention.
    I'm selling a GRX-PRG interface for controlling Lutron GrafikEye units over an RS232 connection to a PC. It's never been used, but was bought by me for a project which is no longer happening.
    The GRX-PRG does the following:
    • Provides a basic RS232 command set that allows a PC to monitor and control lighting.
    • Built-in Astronomic Timeclock provides ability to schedule lighting events. Example: lobby lights turn on to scene 1 at 7:30 a.m. or 10 minutes after sunrise.
    • Enables use of a PC to set up GRX-3500 and GRX-4500 Control Units.
    • Comes with easy-to-use, “point-and-click” Windows®- compatible LIAISONTM software for scheduling the Astronomic Timeclock and using the Programmer Interface.
    Current new cost of one of these is about £800, so getting a second hand one could be bargain way to add this functionality to an existing GrafikEye setup.
    More info on the product can be found here: http://www.easyav.co.uk/?page=product&product=632
    See my advert (on this site) here: http://www.avforums.com/forums/showthread.php?p=1846060
    Thanks,
    Rowland.
