grafic card problem
Discussion in 'PC Gaming & Rigs' started by jelly, Aug 1, 2004.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    hi chaps have a problem with my saphhire radeon 128 on the smartgart screen the agp speed is set to off (usually set to 8x i think) when i try to change the setting it reverts to the original setting after A reboot any ideas
  2. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    942
    46
    +225
    Have you checked the settings for AGP aperture in your BIOS?
  3. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    no what do i do????
  4. HMHB
    HMHB
    Nov 11, 2001
    27,233
    Nottinghamshire
    +6,142
    If yo go into BIOS (keep tapping the delete key when computer is booting up) and look for somewhere where it mentions AGP speed - 2x, 4x, 8x etc then try and change it to 8x. I don't think that the AGP aperture size has anything to do with the speed though.
  5. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    have set the settings in the bios to agp but theres no difference?????????? still is set to off
  6. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    if its set to off and the computer is still booting with visuals it is still working and so is operating at one of those speeds.
    Check under the ATI display settings to see if it says which speed the agp slot is running at. if it does then dont worry too much but if it dosent it could be sign things are about to go pear shaped.
    Try taking the card out and putting it back in again.
