Grado SR60, SR80 or SR125's?
Discussion in 'Headphones, Earphones & Portable Music' started by Splim, Jul 23, 2004.
  1. Splim
    Splim
    Hi All,
    I am about to buy a pair of Grados to replace a set of Beyer DTX900's. I have heard the SR60's and was very impressed (the DTX900's sound 'enclosed' in comparison).
    My question is this, would there be any benefit paying the extra for the SR80's or indeed the SR125's over the 60's as my budget will stretch this far.
    I will be listening via a Denon DM-50 for the moment but will be installing separates gear when I have the room, so any quality advantages that may not be obvious via the Denon will be relevant in the future!
    Thanks in advance for your help
  2. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    I wouldnt bother with any of the others except SR60 unless you have a dedicated headphone amp.
  3. Splim
    Splim
    Went for the 125's in the end! Very impressed, so much more open than the Beyers. Presumably the sound will only improve with my future foray into the separates world, can't wait!
  4. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    I Have the RS1 and Sennheiser 600 with audioart upgrade. Lets just say you won't believe what you hear it's unbelieveable!!! Keep watching on ebay can get Grado's for c£300 and Sennheiser (without cables) for c£110!!
  5. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    I dont think I've ever seen RS1's on ebay for £300 or less. Usually £400 upwards.
    I would go for the HD580 over the HD600, as 99.9% of people wont be able to tell any difference, and the plastic grilles on the 580's are much more hard wearing than the flimsy metal ones on the HD600. The marble effect on the HD600 looks tacky as well.
  6. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    £300 was for american but would send to UK. You can tell the difference with the new headphone connection (audioart) using a headphone amp. I agree about the tacky look but really it's the sound that counts.
  7. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    I just listened to all three this afternoon, and bought a new pair of SR125s --- best value for money at £150 in my view. Open and very impressive sound without sounding like artificial.
