Gpu and boot up issue
Agracing247
Hello,
I'm having trouble getting a display out of my gpu. I recently took out my cpu cooler and gpu for travel and after putting it back together I'm not able to get a display (All lights and fans work, even the gpu fan). I've factored the issue to the gpu because after removing it and using the motherboard hdmi I get a display and also using the other gpu slot doesn't fix the issue.
When trying to troubleshoot with motherboard display I'm getting an infinite loop of being asked to restart and then getting an error. I can access bios and cmd prompt. I can also attempt the recovery process but I ultimately get an error and can't proceed.
I have a tuf gaming z390 plus wifi, asus geforce dual gtx1650 04G, i5 9600k.
Bios ver 2417. Might need to update haven't done so since I put it together Dec2018.
thedude
Ok so does the display work with the mobo or not? Was getting confused.
If it does boot without the gpu in you can go to windows and then update the bios
If it’s not booting it’s could be the mobo or psu
Agracing247
It boots with gpu in, but using motherboard hdmi. Doesn't get to windows just creates a loop to restart or attempting diagnostic then error. Can I update bios from the bios boot screen or cmd prompt? I' think its gpu or needing bios update.
thedude
No idea why you'd need a bios update if it worked before with that bios.
Take the bios battery out for a bit and see if that resets the cosmos
Delvey
Why do we have multiple threads on the matter?
Agracing247
I'm not getting any replies to my latest updates. My thought process is new problems new posts. Im I violating terms? Honestly I just want help to get my pc to working again and I'm doing my best to find solutions to troubleshoot. No disrespect.
iron_monkey
At a guess i would say you have corrupted your boot files and it's not a gpu problem. Google fix boot drive or look into usb boot drive.
Delvey
It is not a new problem though is it? It is all related. And people are not replying because they don't know the solution
