GPU advice for older PC
Mr Regan
Hi guys, just fitted a new evga 600 PSU to my old PC to get it up and running again. I was thinking I could maybe upgrade the GPU to something a bit better.
It's currently got an nvidia GeForce gtx260 installed.
intel core 2 duo malay 2.66gh
Nvidia nforce 680i sli
Corsair xms2 800mhz 4 gig
And was wondering if something like this would work on the old motherboard
http://www.amazon.co.uk/gp/product/B00IDG3IDO?tag=hotukdeals03-21
If so any other recommendations or upgrades I can make to it ram/cpu etc.
it's for running Iracing for a while until I get something decent.
Mr Regan
Mr Regan
Ok guys it seems the price of the GTX 960 has dropped a bit. Would this be ok in my system? Or would it not work. I will be upgrading the MB and CPU at xmas but want something I can use now in the system I have, then use it in the new build.
EndlessWaves
The price of the GTX 960 has been stable around £160 for a while. If you're buying a new CPU then an R9 380 is probably preferable at a similar price.
Given the huge capacity PSU the only limitation you'll face if what will fit in your case and you haven't mentioned what it is or how much space it has.
Mr Regan
EndlessWaves
The trouble with an FM2+ board is that it doesn't take anything other than budget CPUs, the quickest being the £55 860k, equivalent to Intel's pentium-branded chips.
A 270 OC 2GB was a good buy for £42 though.
TheAdamvg
Good buy on the 270. That motherboard isn't a bad price either, although as EndlessWaves said it has a rather limited breadth of chips. Although for a board that cost 16 quid, I wouldn't complain.
