GoW, ranked matches couple of questions...
Discussion in 'Xbox Forums' started by Benny06, Dec 19, 2006.
  1. Benny06
    Benny06
    Jun 11, 2006
    444
    +9
    Hi guys, got my live connection up a few days ago, just found some time to do some ranked matches.
    Its awesome! however the points system confuses me somewhat :confused:
    obviousley the more kills you obtain the more points you acheive. what happens to these points? these arent gamer points, so they dont go on your gamer card, where do they disappear to?
    also one of the acheivments is to finish first in a ranked match for 30 gamer points. Is this just once? or every time u finish first do you achieve 30 extra points?
    if someone could help me out i'd be very greatful :thumbsup:
    thanks
    Benny.
  2. ThePiousFlea
    ThePiousFlea
    Dec 1, 2005
    165
    +6
    They are just to judge your performance and your team's performance in a match.
    Just once.
  3. Benny06
    Benny06
    Jun 11, 2006
    444
    +9
    thanks :smashin:
  4. stepneg
    stepneg
    May 7, 2004
    4,894
    West Sussex
    +354
    Something I only found out the other day is that if you go to leaderboards and select "me" and change the filter to all time then select details it will give you a break down of total kills, points and everything else over the each game type.
