got the speakers but what speaker wire do i get ??
Discussion in 'Home Cinema Speakers' started by jtfab75, Jul 21, 2004.
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    bought some eltax ht2 speakers from ebay,should be coming in a few days.what type of speaker wire do i buy ? the eltax have a wire clip to attach the wire.
    some help would be great.
    thanks
    james
  2. mevetts
    mevetts
    Oct 31, 2003
    439
    QED Silver Anniverary seems very highly rated for the last few years.
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,849
    2
    +3,222
    Or on the same line of thinking (as SA is overkill for rears IMO) have a look at QED Original at £2.50 a metre. Lasts forever and very easy to hide.
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    Good idea Tons, especially as you usually have to run considerably more wire to the rears, so the cheaper price will be better.
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  6. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    QED Original for now for fronts and rears QED Silver if and when you upgrade.
  7. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    QED Qontour Incognito would be my choice. Same performance/price as Original but far more flexible, and almost dead flat. Also smells interesting fresh out of the packet!
  8. Jules
    Jules
    Oct 11, 2000
    5,074
    +752
    Never liked QED speaker cable myself... too bright!
    On the other hand, Gale 315 Strand from Richerssounds is only £1.99 per metre. It's flexible and quite easy to work with.
    Personally, I've tried quite a few cables and thought the Gale 315 was the only one that gave clarity and a real sense of scale with decent bass.
    My entire 7.1 THX system is wired with it, and my choice was based on performance, not price (I was prepared to pay at bit more).
    Really expensive cables I think are just 'different' sounding, not necessarily any better.... but I think this has been widely discussed before.
  9. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,914
    38
    UK
    +7
    Your local electrical shop will sell you some fairly chunky stuff for about 50p a meter and you won't be able to tell the difference. Or mains flex (here he goes again) is just as good.
    At the end of the day, your Eltax speakers are simply not capable of reflecting the differences in cables. I'm not having a go because I have Eltaxes in my office and they are fine speakers for the money. But I would never even consider spending serious money on cables for them. Better to save your cash towards the next (inevitable) upgrade.
  10. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    www.maplin.co.uk code no> XR72P 79 strand hifi speaker cable.
    £0.69 per metre or cheaper by the roll.
    Works perfectly and does not cost much at all. :thumbsup:
