got the plasma now what home cinama amp do i need?
Discussion in 'AV Receivers & Amplifiers' started by dlittlewood, Jun 23, 2005.
  1. dlittlewood
    dlittlewood
    I have recently bought a Hitachi 42PD7200 plasma and the picture is great but I know need to purchase an amp to give me dolby digital 5.1 etc. and I dont have a clue which one to get.
    I have the following kit needing to be hooked up:
    XBOX - component and optical
    DVD - component/hdmi and optical
    SKY+ - RGB scart and optical
    Video - RGB scart and optical
    Pinnacle Showcase - RGB scart and optical
    Any advice would be appreciated.
    Cheers.
  2. carl1234
    carl1234
    Jun 15, 2005
    43
    London
    I have a Sony STR-DB795 7.1 amp which is great and cheap it has dolby digital 5.1/ex/pl2x. DTS 6.1/neo6/96-24 has 4 optical and 2 electrical inputs and 2 component inputs
  3. Astaroth
    Astaroth
    Suspended
    Jun 22, 2004
    3,653
    2
    London
    +882
    Ok you really need to give a budget as I am sure we could suggest a AV 'amp' setup ranging from £50 to £50,000+
  4. scarty16
    scarty16
    Jul 1, 2003
    1,391
    +300
    Don't bother getting one unless it has HDMI/DVI on it otherwise it is out of date before you start.
  5. dlittlewood
    dlittlewood
    Budget would be up to £300 with speakers if possible. Ta.
  6. Petrushka
    Petrushka
    May 23, 2005
    212
    Hoofddorp NL
    +5
    For such requirements and a 300 pound budget you can only choose the Panasonic SA-XR70. You can find it on several webshops for approx GBP 285.
