got the hidef screen now where's the films?
Discussion in 'General TV Discussions Forum' started by stuartam_81, Jun 12, 2005.
  1. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    Hi guys, after much looking round i finally have a panny hidef plasma, and had connected it to a htpc.
    i am currently downloading the hidef demos from the m$ site but when / where can i start buying hidef films on DVD?
    when will we start seeing blu-ray or hddvd players for the PC and the movies disks?
    so many questions, so little time....
    best regards
    stuart moore
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There are a quite a few genuine High Def movies on DVD (uses the MS codec) which require a PC solution or a very rare player which supports wmv. To be honest that format is just a stop gap and marketing strategy in an attempt to corner part of the upcoming HD market. You can import a DVHS machine and while content isn't abundant it is a viable solution for those are desperate for HD.
    WMV related thread
    HD-DVD is still expected to debut this xmas although the price will be very high for the initial player and content will probably upto £10 more expensive than the equivalent DVD version. Not sure if there will be a global launch or like DVD the UK will end up being 12-24 months behind the times. Blu-ray is expected sometime mid 2006, nothing firmer than that really.
  3. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    thanks for the reply, i think i might hold off buying a lot of HiDef dvd's untill HD-DVD is released at Xmas.
    best regards
    stuart moore
  4. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,128
    +773
    not 100% but hd-dvd maybe pushed back till spring 2006 :(
  5. paulfoley
    paulfoley
    Sep 17, 2003
    3,562
    Hants
    +116
    May have been lucky but got a brand new boxed JVC 3000 for £250. I order my films from DVDBoxoffice at £17-19 a pop. The quality is stunning, imagine the hi def clips you download from the web but more punchy, far smoother, full length & with lossless digital sound !
    :thumbsup:
  6. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
  7. leeboy2k3
    leeboy2k3
    Jan 20, 2004
    237
    walsall
    +6
    Or newsbin is your friend for hd movies till the retails anyway. :smashin:
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    what plasma was it you got?
  9. Mark1Ace1
    Mark1Ace1
    I'm fortunate enough to live where we have quite a few hours of HD a week on TV. Can't wait for the next gen of DVD players to come out. Then again, can't wait for the next gen of TV's that have 1080p to come out..:)
    Mark
  10. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    ive got an panny pv500 :D
    thanks for all the replys guys
  11. locky79
    locky79
    Aug 27, 2004
    530
    +8
    anyone tried running HD material via xbox media center? and if anyone knows more about XBMC please message little me :( i got version 2.4 and i havent a clue how to upgrade it :(
    Boo hooo!!
    hullo sir Razor :hiya:
  12. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    Locky :hiya:
    I think you can do divx HD. I dont think WMV HD will work smoothly but I could be wrong on both acounts :suicide:
    :D
  13. Stuart McLean
    Stuart McLean
    You are spot on Razor, because of the Xbox's paltry 733Mhz Celeron it will not decode HD-WMV with any great success. However as you say Divx HD can be done dependant on the bitrate, a mid-range CBR works best.
    I have tried a few (well ok all) of the clips from Divx.com on the Xbox and the do look pretty damn good even if they stutter a little on occasion.
    locky79, Upgrading Media Center is a straightforward process, obtain the latest release (better not say where) and overwrite the existing XBMC folder contents with the new ones, assuming of course that you have a standard installation and have not put anything else in the XBMC folder. Make a backup of your old folder first if you are unsure or in case anything goes wrong.
  14. Andy Leitch
    Andy Leitch
    Apr 27, 2005
    563
    None of your business
    +69
    Absolutely.....my 2Mb connection has been maxed out for the past 3 months.
    Can't get enough HD. \0/ \0/ :thumbsup:
  15. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    :hiya:
    Cheers for confirming Stuart :thumbsup:
  16. scumball
    scumball
    Jan 12, 2004
    6,472
    Harrow - London
    +440
    Has anyone thought of getting a CPU upgrade from friendtech for their XBox/XBMC combo to run HD. I was a bit worried about sending my XBox out to the States but apart from this my Xbox & XBMC is the best bit of kit I have ever bought....especially running 720p into my Panasonic 700 on a 92" screen, just the interface and Project Mayhem III skin look the business. It really was the best £150 I have spent.
  17. zag2me
    zag2me
    Nov 24, 2004
    228
    +17
    :thumbsup: To those who know ;) it aint so hard.
  18. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    I have NTL connection and I can't seem to work out how to use a news group? If anyone can give me some pointers I would be gratefull. :lease:
  19. scumball
    scumball
    Jan 12, 2004
    6,472
    Harrow - London
    +440
    Join a newsgroup provider like usenetserver or newshosting - about £7 a month (you could try the ntl newsgroups but it's unlikely they will hold the binary groups or have a good retention period). Use an indexing service like newsbin to download .nzb files - £1 a month. Use Newsleecher to load the .nzb file and download the file automatically. Voila.
  20. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Grumble, grumble, stupid BT and their stupid caps, grumble can't wait to move out of my parents house...grumble grumble...get my own ADSL :)
  21. locky79
    locky79
    Aug 27, 2004
    530
    +8
    lol my xbox died 2 days ago :( it flash's green and red and doesnt boot up at all :(
    i was messing around with the resolution settings in XBMP and when i turned it off and left it for a few hours i tried again and PoOF flashy lights :(
    ive been tempted to buy a new pc but i shouldnt... temptation is too great with BF2 and all these lovely games coming out. you guys should check out the trailer for enemy terroritry: quake wars!
    :hiya:
  22. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    Locky :hiya:
    Sorry to hear your xbox has died. It didnt over heat did it? BTW I got Battlefied 2 yesterday, I haven't played it yet but I will let you know if it's any good. :D
  23. Stuart McLean
    Stuart McLean
    I think it would be pretty unusual for a FRAG to be caused by XBMP/XBMC (unless its your dashboard and has become corrupted - can you boot with modchip disabled?), these are usually hardware/bios related.
    It would probably be worth your while having a look through the threads on http://forums.xbox-scene.com/index.php answers to most Xbox modding issues can be found there.
  24. Andy Leitch
    Andy Leitch
    Apr 27, 2005
    563
    +69
    http://docs.newzbin.com/UsenetTutorials ....should help you on your way. :)
