Got new speakers and need advice
Discussion in 'Home Cinema Speakers' started by gan*, Nov 12, 2003.
  1. gan*
    gan*
    Oct 18, 2003
    77
    Got some new Mission m34s. Just started using them last night, but sound wasn't that great to one that Ive heard before. Would I need to run them in before they sound good? whats the best way of doing this.
    Also Ive got wooden flooring, and used the domed spikes instead of the sharp spikes. Is this ok, or would I benefit from using spikes and putting something underneath it?
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Gan
    whats the rest of your kit consist of?
    Cheers Gonzo.
  3. gan*
    gan*
    Oct 18, 2003
    77
    Marantz 4400 amp but havent got round to getting a cd player, so using my dvd player at the moment, with coxial cable that came with player.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Quite a few speakers do sound somewhat flat and constricted until run in fully,and this may be your problem.....the easiest way to run them in is simply to use them....there are all manner of running-in regimes used by various folk,but do remember to use music with a reasonable dynamic range,and get the volume up a bit at times(within reason!).
    You mentioned a speaker you'd heard before...what was it?....and as gonzo,says,the rest of your system is just as important when it comes to the overall sound of a system.
  5. gan*
    gan*
    Oct 18, 2003
    77
    What kind of music should I use?
    Ive listened to the older range the m74.
