got my viera 42
Discussion in 'Plasma TVs Forum' started by laurence harvey, Oct 12, 2004.
  1. laurence harvey
    laurence harvey
    John lewis used a firm called goggle box to deliver and install, though the lads did not cable it up correctly so a waste of £35 quid really, thanks to happyh and hornydragon for connection guide, excellent picture via dvd and cable, will order some decent component leads to finish off set up, having a few probs with sound via pioneer amp and correct connections but will work on it. stand is really nice and looks even better with amp and dvd on it, screen is huge , taking some getting used to but glad i ordered 42 inch [again on good advice from forum]
    shame dvd recorder is not multi region[ lot of my disc are imports :( ] but cant grumble for the money.
    got to find somewhere for my centre speaker to go now :(
    so many thanks to all the members who gave me such good advice and hope I can return the favours some time.
  2. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Hi laurence.Glad youre happy with the new arrival.
    I left a shelf out and put the centre speaker, amp and dvd all in the cabinet.Sky box sits behind, out of sight, but the remote still works fine.
  3. laurence harvey
    laurence harvey
    hmmm will try it . thanks again m8 :)
