got my panny c75 today (review)
Discussion in 'Projectors, Screens & Video Processors' started by dancer199, Mar 14, 2002.
  1. dancer199
    dancer199
    I got my panny c75 today and it took all of 10 seconds to set up.
    Its run through s-vhs at the moment and I was really disappointed with the quality of sky digital especially on the selection menu as the yellow highlight of the selector seemed really fuzzy.
    Pictures on sky seemed ok but dvd is absoluty awsome, even in bright daylight the picture was superb. I'll take some screen shots & post them soon, its so much better than my old mitsi.
    I am still debating how to get rgb into the projector. I have had a look at the Lektropack box but dont really understand how I can hook up sky & the dvd into the one box then into the amp & then to the projector. Am I just being a newbee knacker ?
    any advice would be more than welcome
    ta
  2. jrwood
    jrwood
    If your willing to use a PC (these days a decent one can be had for £400) as a HTPC then films on sky with http://www.dscaler.org will pretty much look like DVD's!. I suppose the best way to see if a PC is for you is to buy a cheap WinTV card for £30, stick it in your current PC and then hook up your Sky box via Scart two way cable to composite or svideo (£4.99) in on the WinTV card and run http://www.dscaler.org and see what you think....
    James
