Got my 32ZP48P but PS2 wont show up on EXT4 Via IXOS componant Cable?
Discussion in 'Televisions' started by 9761, Jun 11, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    I get no picture while this is connected to EXT4 which is componant.
    I have connected it to my Componant ports on the back with a IXOS cable but I get no picture on EXT4 which is componant. Ive looked in manual and even looked on the screens menu but nothing!yes both ends of the cable are securely connected!
    Any ideas?
  2. slackbladder
    slackbladder
    Oct 7, 2003
    1,139
    3
    52
    "London, a small village on Mars..."
    +61
    You probably know this but is the PS2 set to component out? I believe it's the Y Cb/Pb Cr/Pr option. It will say Component Video Out (at least it does on my US PS2).
    Apart from that I could'nt say. But it works on two TV's I have with Component inputs.
  3. 9761
    9761
    May 16, 2005
    499
    Hmm I will have a look thanks
  4. 9761
    9761
    May 16, 2005
    499
    yes I found it and switched it from RGB to Y Cb/Pb Cr/Pr and it still didn't do anything, I will see if a Plug in a optical cable and see if that works :confused:
  5. 9761
    9761
    May 16, 2005
    499
    Update: Ive got the Video from the componant on there now but no sound. ive tried with the 2 phono leads that come with the componant cable and the digital optical cable but no sound at all.
    Ive looked at the TV's options and selected DA1 (Optical port) for EXT4 (componant port) but that does nothing.
    Any ideas?
