Got about £800 to spend on a Projector, which one?
Discussion in 'Projectors, Screens & Video Processors' started by mattwhite1, Feb 21, 2014.
  1. mattwhite1
    mattwhite1
    Jul 8, 2003
    277
    Staines aaaaiiiight
    I have had my eye on two for a while now - but as this'll be my first I was hoping for some advice.
    Optoma HD131Xe or Epson EH-TW5200 are the front runners. Both appear to be 1080p and 3D but without a side by side comparison (nowhere nearby that has them) I am a little lost.
    Does anyone have experience of either, or in the £600-£800 region is there another I should be looking at?
    Thanks in advance.
  2. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,981
    Caistor Lincs
    +4,675
    Those 2 and the BenQ 1070/1080 are the ones but you need to check if you see Rainbows.
  3. Pecker
    Pecker
    Dec 26, 2004
    22,487
    Huddersfield, People's Republic of Yorkshire
    +4,608
  4. swedish cook
    swedish cook
    Jul 16, 2006
    619
    28
    +81
    What screen and throw dimensions are you working with, I would have gone for one listed above but my throw distance is too big.
    +1 on the comment above re rainbows, I see them occasionally but they don't bother me, you need to take your family along too.
  5. dasherdiablo1
    dasherdiablo1
    Feb 24, 2014
    270
    28
    +40
    I am in a similar position with a similar budget and the projector I have been most impressed with so far is the Epson EH-TW3200, I would say it is definitely worth a demo if you don't want 3D capability.
  6. Billkaza
    Billkaza
    Feb 25, 2014
    44
    11
    Athens, Greece
    +5
    i would go with HD131xe/hd25e or W1070..
    W1070 faster wheel(less rainbow) better colours out of the box and lens shift(small movement)
    HD131xe/hd25e better blacks but some say more image noise and some focus problems
  7. davee
    davee
    Jun 15, 2004
    717
    twickenham
    +57
    I would go for the Infocus IN8606HD. Cracking little projector for £645 with some cash left over for DVD's
    Good zoom capability, bit of light spill and not too noisy. As always personal choice so a demo is best.
  8. dasherdiablo1
    dasherdiablo1
    Feb 24, 2014
    270
    28
    +40
    I think the problem with the IN8606HD is that it really suffers from the rainbow effect - that may just be because I am rather sensitive to it though. Definitively do a demo before you part with any money!
