Got a tech problem with my LGCX...is this even a problem?
LGCXfan
I have a 65inch LGCX TV that I use as a PC monitor. I booted up my PC this morning to get some school work done(because I use my PC for both gaming and engineering school) and I have a setting on my start bar(or task bar, whatever it's called...it's the bar on the bottom of the screen with the start button lol). The setting is that I have that bar dissapear when I'm not using it.
Anyway, when I brought my mouse down to the start bar to click on my brave icon so I can login to my school, I noticed that my screen is only showing half of the task bar. For those who own an LGCX you know that it's normal for these OLED screens to have around a 1/2 inch gap from the very edge of the glass screen to where the edge of the picture actually starts. But it looks like the bottom edge got bigger this morning. I looked in my NVIDIA settings and none of my display settings have changed, so I ruled out that it's a PC problem. I also switched to the build in operating system of the TV because it's also a smart TV and it's the same thing for the TV's OS.
This TV has probably done this before but I most likely didn't notice this until now.
Anybody have any idea what's going on with my LGCX? Why can I only see half of my start bar now?
Here's a screenshot of what I'm talking about. I keep the wallpaper black and the icons hidden until I need to use them to avoid burn in which is why this image is mostly black except for the half of a start bar at the bottom:
TVWTF
Also note, that since this isn't a PC problem but a TV problem, when I hit printscreen and pasted the screenshot into paint, it showed the entire start bar, so I altered the image in such a way so you can see what I see on my TV.
Thanks for any info ya'all can give on this issue.
LGCXfan
Got an additional question to ask, thanks to another forum I posted this issue at: Am this just a matter of me noticing the 'screen shift' feature that the LGCX comes with to fight against burn in? If that's what is going on here, am I correct to assume that in a few days I'll likely randomly see my whole start bar again?
mikej
I thought the screen shift / pixel orbiter option only moved the picture by a few pixels ? Turning it off should reveal if it is the cause if that's possible on an LG (it is on a Panasonic).
Have you tried changing the TV's aspect ratio and made sure it isn't zoomed in ? 'Overscan' is another setting that can zoom in on the picture slightly, although I think this is normally only an option when viewing the TV's tuner. Worth checking though, just in case.
LGCXfan
Have you tried changing the TV's aspect ratio and made sure it isn't zoomed in ? 'Overscan' can zoom in on the picture slightly, although I think this is normally only an option when viewing the TV's tuner. Worth checking though, just in case.
Wow, thank you! I found my aspect ratio settings and figured out that there is a "just scan" setting where I can chose either on, off, or auto. The setting was on off. I switched it to auto and exited out of the settings menu and the problem is solved. I can see my whole task bar now! WOOT.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
