Got a Pioneer HD display, what now?
Discussion in 'General TV Discussions Forum' started by Neil Fellows, Jul 1, 2004.
  1. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    Ok, dumb question time - I am getting a High Def Pioneer Plasma, and eventually would like to watch High Def TV here in the UK. Exactly what do I need to do this? I don’t have a sky dish, and know little about such items as I’ve never had satellite TV before. Any help would be much appreciated.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Neil,
    Well a usual 45cm Sky dish won't be big enough for the Euro1080 broadcasts as the UK is on the edge of the satellite footprint. A 60cm dish should suffice for most of the UK, and combined with a QS-1080IR receiver, will provide a 720p or 1080i signal for your Pioneer. Sky have announced HD broadcasts starting in 2006, so you could then add another LNB to your dish to receive them - although you would likely also need another receiver ! Hope this helps.
    Steve
  3. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    Steve,
    Thanks for that. I have a feeling that i'll wait untill Sky just does a complete HD package and go for the whole thing in one go. Excuse my lack of tech knowledge, but was is an LNB?
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,278
    Manchester
    +761
    LNB = Low Noise Block converter.
    Most are actually LNBFs with the F standing for integrated Feedhorn.
    It's the bit at the dish that takes a Ku-band signal from the satellite (between 10.9-12.75 GHz normally) and converts it to L-band between 950-2150 MHz to feed it down coaxial cable to your satellite receiver.
    A normal "universal LNB" (or LNBF) has 2 fixed local oscillators at 9.75 and 10.6 GHz ; which one is used depends on the presence or absence of a 22KHz that the STB feeds up the coax along with the 14/18V power. 14 Volts is used for horizontal polarization and 18 volts for vertical.
    More info : http://www.mti.com.tw/default.htm
    Chris Muriel (a satellite anorak in Manchester)
  5. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Well, that told him :eek: :laugh:
