Ended up getting a puncture yesterday after hitting a sharp pointed kerb because some idiot couldn't keep on their side of the road properly.
End result was a puncture on the sidewall meaning it couldn't be repaired. Bit gutted as the tyre is only a year old and cost me £75, had plenty of tread left on it.
Went to the local trusted tyre place and picked up a part worn for £30, cant really afford £75 for a new tyre at the moment but I do prefer to stick to new tyres. The part worn is a Goodyear with lots of tread left on it. Only thing is that once I got home, I noticed that its a winter tyre, none of my other tyres are winter ones. At the time, it was the only tyre of the required size (225/45/17) they had in stock. Will this be OK to use or should I see if they can change it?
Also noticed that it's a run flat when the others on the car aren't.
