Got 2-2.5k to blow on a plasma/lcd - prefer 37" - what do you recommend
Discussion in 'LCD & LED LCD TVs Forum' started by hustler, Sep 8, 2004.
Tags:
  1. hustler
    hustler
    need to use a chipped xbox on it as well..
    peace
    andy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    new PW7 Panny due later this month if you are after a panel only... Of for a TV Sharp 37HV4E LCD a tad over budget, a 42" is not much bigger honestly its 3" taller and 4" wider thats it!!!!! a 42 PW6 panny £2k+ a bit or for £3k Pio 434HDE...
  3. jackylad
    jackylad
    Jul 20, 2004
    161
    16
    What about the new LG 37" LCD.
    QED have it up for £2167.95!!!
    http://www.qed-uk.com/?vp=6&bg=131&bp=37lz30s&bi=0&ird=1405
    It's high res to at 1366x768 with progressive scan.
    I'm thinking of going for that one if the 37PF9986 Philips one on order turns out to not allow a PC input at 1366 x 768. I've been told that the LG screen can be forced to display at native res even though the manual says it doesn't!
  4. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    or the 37 viera
  5. Shepski
    Shepski
    i have the hitachi 37pd5200 and it is superb. had it about 2 months now and still love the quality of picture. also play a modded xbox with hi-def kit using the svideo and it looks stunning. Got mine from cramptons although currys have it for £2299 and if you find the 7.5% discount code on t'internet that brings it down some more ;)
  6. hustler
    hustler
    why do you need an hi-def kit >?
